-   -   what the result is negatif pressure at inlet (http://www.cfd-online.com/Forums/fluent/29196-what-result-negatif-pressure-inlet.html)
chong chee nan December 29, 2001 05:13
Hi
Now I am doing my final year project called 'blood flow in human system' that i required to use FLUENT to simulate a model of artery which high 2mm and length 28mm, blood viscosity 3.5x10-3 kg/ms and 1050kg/m3. I face some problems involve the use of the equation by fluent. the blood flow is under steady, laminar, and Newtonian flow in my simulation. .
For the data above, I found that the result for the velocity is acceptable the mass conservation equation is mesh where the average velocity is similar. And the Couette flow is mesh where average velocity = 2/3 (velocity maximum).
The problem is the static pressure in inlet or outlet of the artery shown in negative values which far away for the setting, the initial pressure is 13332Pa but the average static pressure at inlet = -75.387794Pa. why it happen and which equation is used to get this answer? I also calculated the Couette flow equation and find the differential pressure at pressure with pressure outlet is 58.8Pa according the condition setting in fluent, but the fluent shown 78Pa why it happen
What is the influence of reversed flow at the inlet and outlet of the artery.?
Why the inlet and outlet of the artery shown in negative value pressure, if the boundary condition setting for inlet velocity =0.2, and outflow=flow rate weighting=1
And the initial solution is start for inlet with 0.2m/s nd initial gauge pressure = 13332Pa
modeling steps in this case FLUENT session are reduced to the following:
1 Use Gambit Create the artery model geometry high 2mm and length 28mm and built the grid with 44800 quadrilateral cells, Start the appropriate solver for 2D UNS/fluent5 and built the boundary condition with specific the edges as wall(W), velocity inlet(VI) and outflow(O), Face as fluid. Export the file in msh form.
2 Use FLUENT to Read the grid file and check it. Then adjust the geometry in mm scalar
3 Select the default segregated solver, space 2D, Time Steady, Viscous Laminar, velocity formulation absolute.
4 Specify the material properties.
Material name called blood, with density 1050kg/m3 (constant) , viscosity 3.5x10-3 kg/ms(constant)
5 Specify the boundary conditions.
At zone inlet velocity, set the velocity as 0.2m/s normal to the boundary, set the outflow zone with flow rate weighting as 1 (ratio of flow in to flow out), then set the wall as constant
6 set the operating condition at 101352Pa which is atmosphere pressure
7 set the solution control as the default the under relaxation factor which are pressure, momentum, density and body force, we can reduce the under relaxation factor if the convergence increase or remain constant for a large iteration to achieved the required convergence value. For diiscretization, the setting are pressure= Standard, Momentum= First Order Upwind, pressure-velocity coupling = SIMPLE.
8 Set the continuity , x-velocity, y velocity residual at 0.001 convergence criterion .
9 Initialize the solution.
Set the solution initialization with the initial value below :
Reference frame = Absolute
Gauge pressure =13332 Pa
X-velocity = 0.2m/s
Y-velocity = 0
10 Calculate the solution by start the iteration until the convergence criterion was 0.001 for all residual at step 8.
11 Save the results.
12 Examine the results. There are the result after simulation which shown in graph:
Average Static Pressure (inlet): -75.387794
Average Static Pressure (outlet): -153.41953
Average Dynamic Pressure (inlet): 21.039616
Average Dynamic Pressure (outlet): 25.285543
Average Total Pressure (inlet): -54.348175
Average Total Pressure (outlet): -128.13397
Average Velocity Magnitude (inlet): 0.19950458
Average Velocity Magnitude (outlet): 0.20024745
BELOW IS THE SUMMARY OF THE CASE WHICH GENERAL BY FLUENT
Fluent 5.2.3
> Reading "2.cas"...
44800 quadrilateral cells, zone 1, binary.
80 2D velocity-inlet faces, zone 2, binary.
80 2D outflow faces, zone 3, binary.
560 2D wall faces, zone 4, binary.
560 2D wall faces, zone 5, binary.
88960 2D interior faces, zone 7, binary.
45441 nodes, binary.
45441 node flags, binary.
Done.
Building...
grid,
materials,
interface,
zones,
default-interior
tw
bw
outlet
inlet
blood
Done.
Reading "2.dat"...
Done.
FLUENT
Version: 2d, segregated, lam (2d, segregated, laminar)
Release: 5.2.3
Title:
Models
Model Settings
Space 2D
Time Steady
Viscous Laminar
Heat Transfer Disabled
Melting-Freezing Disabled
Species Transport Disabled
Coupled Dispersed Phase Disabled
Pollutants Disabled
Soot Disabled
Boundary Conditions
Zones
name id type
blood 1 fluid
inlet 2 velocity-inlet
outlet 3 outflow
bw 4 wall
tw 5 wall
default-interior 7 interior
Boundary Conditions
blood
Condition Value
Material Name blood
Specify source terms? no
Source Terms ()
Motion Type 0
X-Velocity Of Zone 0
Y-Velocity Of Zone 0
Rotation speed 0
X-Origin of Rotation-Axis 0
Y-Origin of Rotation-Axis 0
Porous zone? no
X-Component of Direction-1 Vector 1
Y-Component of Direction-1 Vector 0
Direction-1 Viscous Resistance 0
Direction-2 Viscous Resistance 0
Direction-3 Viscous Resistance 0
Direction-1 Inertial Resistance 0
Direction-2 Inertial Resistance 0
Direction-3 Inertial Resistance 0
C0 Coefficient for Power-Law 0
C1 Coefficient for Power-Law 0
inlet
Condition Value
Velocity Specification Method 2
Reference Frame 0
Velocity Magnitude 0.2
X-Velocity 0
Y-Velocity 0
X-Component of Flow Direction 1
Y-Component of Flow Direction 0
X-Component of Axis Direction 1
Y-Component of Axis Direction 0
Z-Component of Axis Direction 0
X-Coordinate of Axis Origin 0
Y-Coordinate of Axis Origin 0
Z-Coordinate of Axis Origin 0
Angular velocity 0
outlet
Condition Value
Flow rate weighting 1
bw
Condition Value
Free Stream Temperature 300
Apply a velocity to this wall? no
Define wall motion relative to adjacent cell zone? yes
Apply a rotational velocity to this wall? no
X-Component of Wall Translation 1
Y-Component of Wall Translation 0
Define wall velocity components? no
X-Component of Wall Translation 0
Rotation Speed 0
X-Position of Rotation-Axis Origin 0
Y-Position of Rotation-Axis Origin 0
Specify shear stress? no
X-component of shear stress 0
Y-component of shear stress 0
tw
Condition Value
Rotation Speed 0
default-interior
Condition Value
Solver Controls
Equations
Equation Solved
Flow yes
Numerics
Numeric Enabled
Absolute Velocity Formulation yes
Relaxation
Variable Relaxation Factor
Pressure 0.0099999998
Momentum 0.0099999998
Density 0.5
Body Forces 0.5
Linear Solver
Solver Termination Residual Reduction
Variable Type Criterion Tolerance
Pressure V-Cycle 0.1
X-Momentum Flexible 0.1 0.7
Y-Momentum Flexible 0.1 0.7
Discretization Scheme
Variable Scheme
Pressure Standard
Momentum First Order Upwind
Pressure-Velocity Coupling SIMPLE
Solution Limits
Quantity Limit
Minimum Absolute Pressure 1
Maximum Absolute Pressure 5000000
Minimum Temperature 1
Maximum Temperature 5000
Thanks your help
Best Regards
Chongcheenan
cnchong78@hotmail.com
