December 30, 2001, 04:07 |
result in negatif value in pressure
hi
for pipe flow, i set the inlet boundary as Velocity Inlet, and outlet boundary as Outflow, on the Initial Window i set compute from inlet boundary with initial gauge pressure = 13332Pa and x-velocity = 0.2m/s. Then i set the Outlet with flow rate weighting = 1. after simulated the pressure at the inlet(<>-75Pa) and outlet(-153Pa) shown in negatif value. what are the procedure and formula used to get the negatif value. The condition under simulated were laminar, steady, 2d, segregated solver and newtonian fluid. |
December 30, 2001, 10:06 |
Re: result in negatif value in pressure
In cfd software, you always use the relative pressure. So you could have a negative relative pressure with a positive pressure.
Pressure averaging at the outlets. | KM | CFX | 6 | April 1, 2021 06:28 |
Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 13:45 |
Boundary Conditions : Total Pressure or Velocity | Gearb0x | OpenFOAM Running, Solving & CFD | 2 | February 28, 2011 21:18 |
UDF to define or adjust pressure??? | engahmed | FLUENT | 0 | July 6, 2010 17:19 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
