How to determine a steady flow?
Old   December 28, 2001, 22:58
Default How to determine a steady flow?
Frankie
Currently, I am simulating the unsteady air flow in a gas turbine enclosure. How could I know whether the flow has become steady or not?
Old   December 29, 2001, 08:17
Default Re: How to determine a steady flow?
Andy
You can set up a macro to record the turbulent viscosity, say every 50 iterations, and leave the simulation running for say 500-1000 iterations. If you have an animation package, paint-shop pro, then you will be able to animate the above 10 or more slides to see any wake or 'unsteadiness' in the flow field. It is a brilliant way to visualise the flow field in a global manor. Of course it does not provide any mathematical verification of a steady flow, it is purely visual, however, will there really be any purely steady flow?
Andy
Old   December 29, 2001, 19:25
david
if you don't have time to see/make the animations, try to monitor the gradient of solution parameters at some critical points.
DC
Old   January 2, 2002, 20:58
Frankie
What do you mena by the 'gradient' of solution parameter?
Old   January 5, 2002, 19:18
dave
for example gradient of velocity component at some critical points. dv/dx for example
initialize flow field with steady state solution holg FLUENT 0 July 13, 2009 17:10
Appropriate model for turbulent, steady state pipe elbow flow milos OpenFOAM Running, Solving & CFD 4 July 9, 2009 02:24
Unable to achieve a steady flow lost.identity Main CFD Forum 1 April 29, 2009 10:22
Steady Pipe flow Usman FLUENT 0 November 20, 2007 06:40
steady and unsteady flow shisheng Main CFD Forum 10 July 23, 1999 06:00
