January 3, 2002, 07:46 |
Time Dependant solution
I am wanting to model two phase flow into a chamber initially containing only one phase and to monitor the initial mixing before equilibrium is acheived. Is it possible to do this in FLUENT?
January 5, 2002, 14:05 |
Re: Time Dependant solution
yes it is possible
January 7, 2002, 04:44 |
Please could you describe how to do it?
January 9, 2002, 13:14 |
Use a multiphase model in FLUENT. Check http://www.fluentusers.com/fluent5/training/9amulti.pdf for a review of which model is most appropriate for the physics of your problems and what you are expecting from your solution.
Display Modes | |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 12:08 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
calculation diverge after continue to run | zhajingjing | OpenFOAM | 0 | April 28, 2010 05:35 |
AMG versus ICCG | msrinath80 | OpenFOAM Running, Solving & CFD | 2 | November 7, 2006 16:15 |
How to read out time used for current solution | Angelo Sozzi | FLUENT | 1 | July 7, 2004 14:16 |
