-   FLUENT (
-   -   Cooling Coils - Elbows (
Eric R. January 10, 2002 13:21
Hello Gambit/Fluent users:
I am creating 3-D helical cooling coils in a tank in AutoCAD and would like to import it into Gambit; similar to the picture in this link (courtesy of Fluent News):
I need to attach a 90 degree elbow on each end of the coil bank so that I can run it out of the top of the tank. This might be more of an AutoCAD question, but I cannot join a 3-D polyline and a 2-D polyline! I used a 3Dspiral LISP program to create the center line for the coils, and extruded a 2-D circle along the path to create my volume. You can start a 2-D polyline from the endpoint of the 3-D polyline, but you cannot extrude over the length of the entire geometry (coil + 2 elbows) because you cannot join or union 2D & 3D polylines. The path needs to be pretty symmetric b/c I need to use the cooper meshing scheme.
If you have any advice or have experienced this before, I would greatly appreciate any suggestions you may have. Thank you.
