-   FLUENT (
-   -   defined order of react ??? (
hsin ping chang January 15, 2002 01:34
Today , i would like to simulate two mixtures that flow through the different channel respectively . First mixture(include hydrogen ,water-vapor)flow in top channel. second mixture (include oxygen , water-vapor , nitrogen)flow in below channel . but two channel contact together . the surface area is wall between top channel and below channel . i want to ask how to defined the order of react of species(total four species )inside in Fluent 5.5 solver. Defines/Materials/Mixtures species panel
Jin-Wook LEE January 15, 2002 02:27
Re: defined order of react ???
You should define at least 5 species.
H2O, N2, O2, H2, CO2
Maybe you should define more specises for intermediate species.
For one step reaction model, you can refer the reaction parameters from the
It's fairly simple one-step reaction model.
And you can also use 'MF(Mixture Fraction)/PDF Model.
For more information, I think that you should study, because it's fairly difficult to fully explain the modeling strtergy of combustion simulation because combustion itself is fairly difficult.
Sincerely, Jinwook
Jin-Wook LEE January 15, 2002 04:48
Sorry, you don't need CO2.
Sincerely, Jinwook
