defined order of react ???
Old   January 15, 2002, 00:34
Default defined order of react ???
hsin ping chang
Today , i would like to simulate two mixtures that flow through the different channel respectively . First mixture(include hydrogen ,water-vapor)flow in top channel. second mixture (include oxygen , water-vapor , nitrogen)flow in below channel . but two channel contact together . the surface area is wall between top channel and below channel . i want to ask how to defined the order of react of species(total four species )inside in Fluent 5.5 solver. Defines/Materials/Mixtures species panel
Old   January 15, 2002, 01:27
Default Re: defined order of react ???
Jin-Wook LEE
You should define at least 5 species.
H2O, N2, O2, H2, CO2
Maybe you should define more specises for intermediate species.
For one step reaction model, you can refer the reaction parameters from the
DEFINE --> MATERIAL --> DATABASE --> 'MIXTURE MATERIALS, Hydrogen-Air --> REACTION MODEL --> VIEW
It's fairly simple one-step reaction model.
And you can also use 'MF(Mixture Fraction)/PDF Model.
For more information, I think that you should study, because it's fairly difficult to fully explain the modeling strtergy of combustion simulation because combustion itself is fairly difficult.
Sincerely, Jinwook
Old   January 15, 2002, 03:48
Jin-Wook LEE
Sorry, you don't need CO2.
Sincerely, Jinwook
2nd order upwind vs 2nd order upwind!!! Far Main CFD Forum 7 March 14, 2013 12:29
1st order vs 2nd order ken FLUENT 8 March 14, 2013 03:43
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
How to defined the order of react ?? kevin FLUENT 0 December 18, 2001 08:35
defined order of react ???? joby FLUENT 0 November 27, 2001 01:00
