January 15, 2002, 03:05 |
More GAMBIT
Hi.
When meshing with the Coopet tool, the Gambit online manual have an example on how to mesh a combination of a cylinder, a box and a "corner". The operation is divided in 4 steps. Step no.2 is an imprint of the source faces onto each other. My question is how this imprint is done. Is it done just by selecting the source faces or is there a special command that should be used (if yes: there is this command; I cannot find it). Thanks Christian |
January 15, 2002, 17:35 |
Re: More GAMBIT
Done automatically after you select the source faces
January 16, 2002, 02:54 |
Re: More GAMBIT
Ok. Thank you.
Display Modes | |
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 06:29 |
Gambit 2.3.16, Xming or Exceed...HELP! | bambam3417 | FLUENT | 10 | May 7, 2010 12:39 |
Does Gambit has a maximum allowable grid number? | spartan1516 | ANSYS Meshing & Geometry | 7 | March 25, 2010 09:08 |
Gambit -dev X11 doesn't work | Ervin Amet | FLUENT | 0 | October 28, 2007 08:33 |
Problem starting Gambit | ViHAR MALViYA | FLUENT | 0 | November 10, 2006 10:26 |
