annular diffuser problem
Old   January 16, 2002, 01:55
Default annular diffuser problem
puneet gupta
hello i am a student of iit delhi and working on annular diffuser problem (2d)on fluent 5.5. i am facing great difficulty in defining the axis for this annular pipe flow configuration. i have meshed the flow regime in the annulus but how do i define the axis to denote the cylindrical shape of the pipe and not a flow between 2 plates in 2d. since the axis for the annulus flow is outside the flow domain, i wanted to know how to define the same in a 2D case and not 3D. i am using gambit for drawing the geometry.
Old   January 16, 2002, 10:46
Default Re: annular diffuser problem
Erwin
Can't you model a small portion upstream of the diffuser? This would also better define the flow going into the diffuser.
Old   January 16, 2002, 15:20
Puneet Gupta
Thank you for your suggestion but I guess i could not explain it well. Let me take a very simple case. How do I declare axis for an annular flow in two concentric cyclindrcal pipes. Unlike in flow thru a normal pipe where the axis is a part of flow regime, for annular flow, the axis lies outside the flow domain. so how do i define it in Gambit?
Old   January 16, 2002, 15:46
Jonas Larsson
You define this inside Fluent (Boundary Conditions, Fluid, Axis of Rotation... or something like that). I think that in some cases Fluent requires that it is the x-axis which is the rotational axis, so the x-axis is a safe choice. In Gambit you just place your two end-walls so that the x-axis becomes the rotational axis.
Old   January 16, 2002, 16:15
Puneet Gupta
Hello Thank you for your advise. I will definitely try looking for the option of axiz of rotation in fluent. But I am still not clear about Gambit. I have constructed the annular geometry at some distance parallel to the x axis but can not figure out how to declare the axis ( isnt my problem definition in gambit still incomplete in Gambit) Looking forward to your help Puneet IIT Delhi
Old   January 16, 2002, 16:46
Jonas Larsson
I assume that you want to create a 2D mesh, in that case you don't need to define any axis of rotation in Gambit. It is enough to define it in Fluent.
Old   January 17, 2002, 13:58
Michael Bierdel
In a 2d case the x-axis is the axis of rotation, in a 3d case the z-axis is the axis of rotation. To start a 2d axisymmetirc calculation in Fluent go to Define-Solver in the menu and check the corresponding box on the left.
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 10 February 7, 2024 21:50
conduction problem venkataramana OpenFOAM 3 December 1, 2013 07:30
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
Problem in implementing cht tilek CFX 3 May 8, 2011 08:39
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
