-   -   compressible flow boundary conditions (http://www.cfd-online.com/Forums/fluent/29270-compressible-flow-boundary-conditions.html)
yangqing January 21, 2002 11:34
for compressible flow. can it lead to error that specify the inlet with vilocity inlet? i have tried a case,the residual of mass rise very fast.then disconvegence
Karl January 21, 2002 13:10
Re: compressible flow boundary conditions
For compressible flow a "Mass Flow Inlet" - boundary will give you better results. For the outlet boundary use "Pressure Outlet" , but you have to be careful to set proper values for the backflow values (only needed if reversed flow occurs at the outlet).
yangqing January 22, 2002 11:19
in my case,oulet is a mechanic fan. i only know the mass flow rate, not the pressure jump. how can i specify the out boundary condition thanks
