the max iteration numbers in one time step
Old   January 28, 2002, 10:53
Default the max iteration numbers in one time step
yangqing
solving unsteady flow, there is a max itration numbers in one time step. what's meanning. whether or not the solution will turn to next time step if it couldn't reach a convergence solution for max iteration numbers in this time step. if i want to reach a convergence solution for every time step, what shall i do? thanks
Old   January 28, 2002, 11:35
Default Re: the max iteration numbers in one time step
hvn
You could increase the number of max iteration in one time step to an important value like for example 100000.
Old   January 29, 2002, 10:39
yangqing
is that the only way? thanks
Old   January 30, 2002, 08:23
mw
Best thing is to reduce time step size until the residuals drop by two-three orders of magnitude in 5-10 iterations per time step.
Old   February 1, 2002, 10:24
yangqing
thanks for mw, hvn
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 09:20
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 20:21
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
