total pressure change in a pipe flow
Old   February 5, 2002, 20:16
Default total pressure change in a pipe flow
Im
hi everybody. I have been solve pipe flow with orifice. It's very simple problem. The pipe size is L=50m, D=1.0m. It has orifice at L=10m. As everybody knows, the recirculation region occured right after orifice. Because of these recirculating flow, the total pressure dropped suddenly. Now, My problem is that. The average total pressure at around orifice is lower than outlet average total pressure. Is it possible ? As I know, The static pressure at recirculation region is possibly lower than outlet pressure. Decreased static pressure can be increased as dynamic pressure decrease. but the total pressure never can increase without any additional energy. What is wrong? The solution of fluent or my thought that the total pressure never can increased without any addtional energy. If my idea is wrong, please let me know the mechanism of total pressure gain. thanks in advance.
Old   February 6, 2002, 09:46
Default Re: total pressure change in a pipe flow
hervé
Make sure that you are using the so-called "mass-weighted" averaging.
If not, try it, you should see a decrease in the so-averaged total pressure.
Old   February 6, 2002, 12:50
Amadou Sowe
What fluid material are you using?
Old   February 6, 2002, 19:07
Im
I tried all kinds of average method. vertex, facet, mass weighted etc... As change averaging method, the magnitude of total pressure changed, but there is no change in the tendency.
Old   February 6, 2002, 19:09
Im
I used air. I just change the density and viscosity. density = 0.82kg/m^3, and viscosity = 0.1cp
Old   February 23, 2017, 08:55
Jittanakatti
anand.jittanakatti is on a distinguished road
It looks like due to wake there is a vacuum next to sudden expansion or the orifice, which is causing the total pressure decrease refer below link
http://www-mdp.eng.cam.ac.uk/web/lib...is/node55.html
anand.jittanakatti is offline   Reply With Quote
Maintaining Static Pressure at Fluid Flow Inlet cdevalve FLUENT 3 January 14, 2012 00:11
Boundary Conditions : Total Pressure or Velocity Gearb0x OpenFOAM Running, Solving & CFD 2 February 28, 2011 21:18
Pipe Flow - Pressure Drop Daniel L FLOW-3D 2 December 10, 2010 04:23
Total pressure in a laval nozzle Sohail Ahmed FLUENT 0 May 19, 2004 05:28
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
