How to start?
Old   February 13, 2002, 00:11
Default How to start?
bfan
I select Start->program->Fluent Inc->Fluent 5.5->2D. and it appears the flowing message, what should I do? (on Windows2000,P4)
Cannot connect to license server The server (lmgrd) has not been started yet, or the wrong port@host or license file is being used, or the port or hostname in the license file has been changed. Feature: fluent Server name: me2k License path: C:\FLUENT.INC\license\license.dat; FLEXlm error: -15,10. System Error: 10061 "WinSock: Connection refused" For further information, refer to the FLEXlm End User Manual, available at "www.globetrotter.com".
Hit return to exit.
Interrupting... Done. Error encountered in critical code section
Hit return to exit.
Old   February 13, 2002, 06:27
Default Re: How to start?
Andrew Parker
Do as it tells you, and go to the website and search for your specific error, -15,10, it will tell you what to do!
Andy
Old   February 13, 2002, 10:45
Scott Whitney
I struggled for quite some time with this myself. The globetrotter website is almost useless, and unfortunately the Fluent customer service is almost useless with these problems.
Have you done all of these? 1) Obtained a current license file from Fluent. 2) Copied this license file to all computers that you want to run Fluent (including the server). 3) Installed the license software on the server listed in the Fluent license file. If the Fluent license does not match the server computer's name exactly, you will get an error. You can alter this name in the license file by hand. 4) Installed the license software on all computers you wish to use Fluent. 5) Started the License Server software on the server. 6) Make sure that there is a good connection between the Fluent computers and the Fluent server. If your network is down, you cannot start Fluent. In the License Server program there are buttons to check if the connection is working and to check if the license is valid. 7) Make sure that all computers have the correct date and that their clocks are within a few minutes of each other.
Those seven steps have solved all my FLEXlm problems. Every time I install Fluent on another computer it refuses to start until I triple check all those seven steps. It usually ends up that the computer date or time was slightly off.
Old   February 13, 2002, 15:59
bfan
Thanks for your kindly reply! Yes, My problem is caused by the disconnection with the server.
Old   February 13, 2002, 19:01
Scott Whitney
You are welcome.
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 06:55
Transient DPM-About Start Stop times Julie FLUENT 3 January 24, 2014 07:39
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
Start star ccm+ remotely with mpiexec Dagnir Siemens 0 November 24, 2010 12:33
Lets start the public domain CFD-Project! Heinz Wilkening Main CFD Forum 3 March 11, 1999 22:55
