How to deduce the residual?
Old   February 19, 2002, 11:17
Default How to deduce the residual?
Jie
Hello, guys,
After 10000 interation or even 20000 , all my variables are below 1e -3 even 1e-5,but one variable--Y velocity is still a little above 1e-3. This value lasted for 10000 interations Anyone has ideas to decrease it?
Thanks
Jie
Old   February 22, 2002, 05:27
Default Re: How to deduce the residual?
Jin-Wook LEE
Then, as my personal point of view, it might be O.K. if other situation is consistent, for example, both of heat balance and material balance are O.K.
If you really want to decrease the residual to slightly lower value, just decrease underrelaxation parameters dramatically, e.g., 0.05, and do couple of iterations(10 iteration is enough, I think). But it is, I think, just a trick. The result is not changed so much.
Sincerely, Jinwook
transsonic nozzle with rhoSimpleFoam Unseen OpenFOAM Running, Solving & CFD 8 July 1, 2022 06:54
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
