mass flow rate of a dispersion phase
Old   February 24, 2002, 02:41
Default mass flow rate of a dispersion phase
Paul
Hi, anybody,
I think you are so kind tell me that if I can calculate the mass flow rate of a dispersion phase at each outlet boundary. Now I'm simulating a separating device by FLUENT5.4. This device has two outlets. I want to know its separating efficiency. So I must know the mass flow rate at two outlets.
Sincerely, Paul
Old   February 25, 2002, 23:19
Default Re: mass flow rate of a dispersion phase
Jin-Wook LEE
Use Display-->Particle-Track panel. Set report type as 'summary'. Then Fluent reports escaped zone and particle number etc.
Sincerely, Jinwook
mass flow rate not conserved in turbomachine, interface defined wrong? wildli FLUENT 3 September 15, 2022 12:19
Mass flow rate: calculation v/s computation beguxa FLUENT 5 December 2, 2018 21:02
UDF to measure Mass Flow Rate a.lynchy Fluent UDF and Scheme Programming 31 October 4, 2018 14:10
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 10:44
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
