Gambit - all blades
I just start to model flow throught Francis turbine. Well I need also to mesh all stator blades. I try to mesh only one blade-to-blade passage and then copy mesh no_blade times. Finall mesh is OK but with wall zone between two meshes. Does someone know how can I make in GAMBIT a finall mesh for all bledes with one meshed blade passage? Thanks in advance |
Re: Gambit - all blades
Switch to Fluent and fuse the walls to interiors. But be sure you have identical mesh on both walls. Kim
Thanks Kim
