GAMBIT QUESTION
Old   March 5, 2002, 15:30
Default GAMBIT QUESTION
stephen davis
In Gambit, what does this mean:
"Meshing volume volume.4 aborted because it has invalid topology."
Is there anyway to mesh a volume with this statement.
Old   March 6, 2002, 03:29
Default Re: GAMBIT QUESTION
Tomas
Maybe are there virtual faces or lines that aren't connected? Otherwise I don't know! Good luck!
Old   March 8, 2002, 22:55
harry
maybe your grid is not consistent
Old   March 11, 2002, 10:52
Default Probably a vertex mixup!
Erwin
I have had problems in the past that seemed like yours, an error message that I didn't understand and no way to mesh the volume. My solution to the problem was to check all the vertices. It is possible that you inadvertently created multiple vertices at the same or nearly same location. Subsequently weird and open volumes are created from these vertices if you don't know they are there. So do this:
go to the 'Summarize Vertices' panel, and shift-leftclick on a vertex. Note the vertex number and then shift-middleclick on that same vertex. Check if the number changes, if it does then you're in trouble.
Gambit maillage question stage81 FLUENT 0 October 1, 2010 10:06
Gambit question. Pablo Cornejo FLUENT 10 March 10, 2006 09:46
Gambit question LI Y FLUENT 2 April 6, 2003 16:59
a question about Gambit Jack FLUENT 5 February 6, 2003 06:04
an easy question about gambit brian FLUENT 3 December 2, 2002 23:58
