Negative Stream Function Values - How do I get the |
March 13, 2002, 11:17 |
I am currently simulating stokes flow (Re = 0) in a single lid driven cavity. It is a 1m by 1m cavity where the driving wall translates at 1m/s.
As one would expect I find a main central eddy and two eddies in the corners opposite the moving wall. However these are counter-rotating and so should have a diiferent sign to the main eddy. I can only find positive values. Does anyone have any suggestions on why I don't see these changes of sign? There are many journal articles which back me up that these corner eddies should be negative. Comments and suggestions would be greatfully recieved. |
March 13, 2002, 20:10 |
Re: Negative Stream Function Values - How do I get
It's dependent of the location of reference value(psi=0). Even though the value of small eddy is positive, I am sure that it is relatively negative compared to the value of dividing line(boundary of central eddy and corner eddy).
Sincerely, Jinwook |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 06:59 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
HELP - stream function from the velocity field | Fred | Main CFD Forum | 10 | January 26, 1999 12:58 |
Stream function and vorticity for turbulence flow? | Willard Lee | Main CFD Forum | 1 | January 20, 1999 11:03 |
