Tgrid on RH_Linux_72
Old   April 3, 2002, 07:02
Default Tgrid on RH_Linux_72
pp
Anybody try to install Tgrid on RedHat Linux 7.2. I have problems with opening File-Open And File-Write box's.
Thanks
Old   April 3, 2002, 07:15
Default Re: Tgrid on RH_Linux_72
Jonas Larsson
Yes, it is the same problem which affects FLUENT 5 on RedHat 7.1 and 7.2.
I don't know if Fluent has a version of Tgrid which works on 7.2 - you had better ask your support engineer. They solved the problems in FLUENT 5 (with the inofficial 5.7 release) so they should know how to fix it.
If you manage to get a fixed Tgrid version from Fluent please let us know.
Old   April 10, 2002, 15:08
Shyam Kishor
The problem has been fixed. Next release (Q3 of this year) of TGrid will be supported on RH_Linux_7.2. In case you have un urgent need, please contact your local Fluent Support Engineer to request a prerelease version.
[Commercial meshers] Cannot convert fluent or tgrid hexcore mesh aerogt3 OpenFOAM Meshing & Mesh Conversion 2 October 22, 2010 11:55
CFX Pre - TGrid Vivek Vasudevan CFX 2 March 20, 2007 06:31
TGrid: segmentation violation error Vincent FLUENT 0 February 15, 2006 10:34
Drawing in TGrid Harmeet FLUENT 0 September 22, 2004 03:56
to tgrid or not to tgrid Nurul Murad FLUENT 1 July 6, 2001 13:21
