-   -   Help-Gambit-Changing geometry color (http://www.cfd-online.com/Forums/fluent/29581-help-gambit-changing-geometry-color.html)
Shankar April 3, 2002 12:23
Hello all,
Can anybody tell me how to change the geometry color in Gambit from green to black?I aasume it should be in the edit , default menu , but how do I change it? Regards, Shankar.
tang April 4, 2002 03:38
Re: Help-Gambit-Changing geometry color
pls check the menu EDIT\DEFAULTS\GEOMETRY\vorvex, edge, face or volume
Jan April 9, 2002 18:00
Changing the default will change the color of any future entities that you create. If you want to modify the color of an existing entity, go to the Modify *Entity* Color form. If you go to the Geometry operations button, then select any entity below it (group/volume/face/edge/vertex), the Modify Color form will always be the 5th button in the third row.
Shankar April 10, 2002 22:11
Thanks a lot to both of you
