force calculations
Old   March 27, 2002, 10:39
Default force calculations
khalil
hi all, i'm trying to produce a plot of force against time for a cylinder shedding vortices, i've run out of ideas, does it require udf?
all help very much appreciated
thanks
Old   March 28, 2002, 08:55
Default Re: force calculations
patel
if you can't figure it then you caould always blag it, if you want advice on blagging you need to speak to ash,(that's if you get hold of him b4 May) this guy is world renowned for his technical blagging ability.. email: ashiq.khalid.hussain@stud.man.ac.uk
lets us know how u get on..
thanks
Old   March 30, 2002, 19:40
david
A) You need series of data files at different times B) Write a script file to read one case file and series of data files and offers you that force for each time steps. C) The smartest thing is to before you start the calculation, save/write/monitor ONLY that particular force (this will avoid you from saving the data files)
DC
Old   April 7, 2002, 11:41
Zahir
hey khalil check out this link, it's got some cool stuff, looks like someone's done the work for you..
http://www.city.ac.uk/hydraulics/CFD/animjava.html
Force can not converge colopolo CFX 13 October 4, 2011 22:03
User-defined force transfer across FSI interface vivekcfd CFX 7 March 10, 2010 20:43
Urgently Need the code of Lift force and VM force Kai Yan Main CFD Forum 0 July 16, 2008 07:07
DEFINE_CG_MOTION and pressure force Teo Fumagalli FLUENT 0 April 11, 2008 10:25
pressure force and viscous force CFD FLUENT 0 March 7, 2006 01:03
