Licensing problem with Fluent v5.5
Old   March 18, 2002, 22:28
Default Licensing problem with Fluent v5.5
moiami
My friends and I are having this problem. It seems that our new license for Fluent v5.5 doesn't work with the older versions (v5.3 and Fluent 4). Are we the only ones with this problem? If anyone has encountered it please tell me how you solved it because we have to use Fluent 4 for our projects (v4.5 for running Mixsim and v4.4 for multiphase solids).
Thank you
Old   March 19, 2002, 12:28
Default Re: Licensing problem with Fluent v5.5
Evan Rosenbaum
You will need to contact FLUENT and get them to create a license file that contains entries for the specific older versions that you wish to run.
Old   March 19, 2002, 21:38
moiami
Thank you very much. I'll forward this message to my supervisors.
Old   April 17, 2002, 03:50
moiami
Okay, for anyone running into the same problem ... the problem was settled by installing Fluent v5.5 and v4.5.6 in the server first. Lower version (v4.5.5 etc.) will not be able to run.
fluent parallel problem in win7 x64 system dunga82 FLUENT 8 April 19, 2012 20:23
fluent convergence problem josip76 FLUENT 0 May 26, 2011 20:08
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
Fluent boundary conditions problem bobo FLUENT 2 July 3, 2009 06:28
Fluent parallel license problem brothershuai Main CFD Forum 0 July 1, 2009 15:41
