surface tension in VOF
Old   April 10, 2002, 01:06
Default surface tension in VOF
New1
Hi, I'm runing some 2D simulation of gas and liquid flow over tubes using the VOF model. The results are OK until I introduce the surface tension. The values I use are around 25 dynes/cm or 0.025 N/m as demanded by the panel in fluent. The problem I have is that when I introduce this value the results are, I think, not realistic. The surface became almost a plane (flat line). The tubes I use are in milimeters and I've changed the units in the grid->scale-change units option. I wonder if I need to change the surface tension units accordingly.
Thanks for any info.
New1
modeling pipe flow with strong surface tension phsieh2005 OpenFOAM 0 August 27, 2009 13:51
VOF method +surface tension yapalparvi OpenFOAM Running, Solving & CFD 5 July 17, 2009 03:56
Inconstant Surface Tension on Interface in VOF Atieh CFX 4 February 10, 2007 15:47
free surface of VOF and melting model? wanghong FLUENT 3 March 13, 2006 09:57
surface tension model in EX26 Junhua Wu FLUENT 0 June 7, 2000 10:49
