animations
Old   April 12, 2002, 13:39
Default animations
vineet
hi,
i am solving unsteady flow and want to get a movie or animation of the veovity vector plots. i want to do this by getting plots after regular no of iterations (say 10). If anyone knows how to do it please inform me.
thanks, vineet
Old   April 13, 2002, 05:17
Default Re: animations
kim
See the chapter 20.6.3 in manual, called "Saving an animation". In the paragraph "Hardcopy file" you will find all you need. Kim
Old   April 13, 2002, 06:31
khalil
looking through the archives i found these instrucions on how to animate an unsteay solution. it may be more useful to produce an image every time-step as apposed to iteration.
1 Set up the view interactively as you want it.
2 Go to File/Hardcopy and set up the output format and size you want (I used tiff and 560x400 pixels)
3 Go to Solve/Monitors/Commands, add one comand to be performed every iteration. In the command field write a text comman which plots and saves what you want. Here is an example: /display contours vel /display hard-copy vel%t.tiff
once you've collected all your images you need a animation package (one can be downloaded from shareware internet sites) and compile.
Old   April 13, 2002, 12:11
vineet
thanks khalil,
actually, the problem is i do not know the correct command to be given to plot the velocity vectors. If you know then please do let me know or else i will have to manually save each of the velocity vector plots then make a animation ( lot of work ).
Old   April 14, 2002, 06:01
Rajeev
Hi Vineet,
If you know how to display the plots through the menu then.
Use the text commands instead, like
type display at > and press enter. It will change to display/ Press enter then you will find lot of commands available under display. Select the command which suits your case. This way you can see that a series of text commands can be built up. While you are doing this keep writing them on a piece of paper. When you achieve your desired result you have the command built up.
This command should be placed in the command text box and with %t as Mr. Khalil pointed out. This might help.
I normally write all the commands for setting up case files, running the case file in a journal file and use it.
For example to iterate 100 times you can type
solve iterate 100 at the text prompt and this will iterate 100 times.
Animations for C++ in CFD Emre Turkoz Main CFD Forum 5 February 15, 2011 03:45
CFD Animations of breaking waves Dommermuth Main CFD Forum 0 June 17, 2009 11:47
CFD Animations of waves, ships, and turbulence---- Douglas Dommermuth Main CFD Forum 23 January 8, 2008 12:41
Fluent Animations AndyC FLUENT 3 July 13, 2007 09:01
Storing animations of pathlines &particle tracks Rodrigo FLUENT 4 August 12, 2004 10:40
