April 17, 2002, 13:25 |
Smoke visibility
Dear Fluent users,
Has anyone got experience in modelling a smokesource in Fluent and setting up a value for visibility. We are allso interested in the relation between smokeproduction and heat output. Thanks in advance. |
April 18, 2002, 09:34 |
Re: Smoke visibility
stricly speaking, smoke is a combination of carbon particulates (1-20 micron dia) and gases ... i usually model smoke as the products of the chemical equation describing the combustion and so i usually model a mixture of air and "smoke" with an air mass sink to account for oxygen consumption and a smoke mass source plus the energy source.
to report, in the way of post-processing, for the visibility in the domain of interest... visibility post-processing is related to the mass concentration of the smoke and several fluent customers do this regularly ... here is some background information on smoke production and visibility: http://fire.nist.gov/bfrlpubs/fire95/PDF/f95126.pdf http://fire.nist.gov/bfrlpubs/fire00/PDF/f00164.pdf basically visibility can be defined as the distance at which the contrast of an object relative to its backgrounds drops below a certain fraction. the visibility S, [m] depends on the smoke mass concentration C, [g/m3] and on the specific extinction coefficient Km, [m2/g] which depends on the material being burned for a light emitting sign S = 8 / (Km*C) for a light reflecting sign S = 3 / (Km*C) this is simple to create a post-processing variable in fluent because the smoke concentration density is readily available |
December 5, 2020, 07:01 |
#3 | |
Mahesh
Rep Power: 6 |
December 5, 2020, 10:21 |
Rep Power: 26 |
December 5, 2020, 11:01 |
Mahesh
Rep Power: 6 |
Sry for my mistake. I meant to say that the visibility is becoming infinite where the smoke concentration is zero and I could not plot the visibility as the post processing shows error. Kindly help me how to plot in such case.
Thanks in advance |
December 5, 2020, 15:05 |
Rep Power: 26 |
Make it finite but a big value in such case. I have no idea how you implemented this, because you did not give any info, so I can't tell you how to change your implementation.
Display Modes | |
Car park ventilation and impulse fans | guillaume | Phoenics | 9 | October 27, 2015 06:57 |
Fire & Smoke in Building | Jenn | FLUENT | 5 | December 30, 2012 00:15 |
Questions about smoke modeling using CFX | rafiktharwat | CFX | 0 | March 14, 2011 12:38 |
visibility level vs smoke | suti | Phoenics | 1 | May 21, 2004 13:39 |
smoke & screen | Marko | Main CFD Forum | 12 | May 15, 2000 12:56 |
