UDF for source terms
Old   April 3, 2002, 12:05
Default UDF for source terms
Tom
I want to define a source term in a porous region which is included in a domain (material is air). This domain is heated from the bottom, where the porous is located, so there is a temperature gradient between bottom and top of the domain. This source will be a function of the temperature difference between the temperature of the domain (space without the porous) and the temperature of the porous. Any ideas? Thanks
Old   April 26, 2002, 01:13
Default Re: UDF for source terms
Hiranya
It seems that you are going to add only energy source term in the porous region. You have to know the amount of heat (Q) added to the porous zone in terms of Watts (J/s). Also I think that the porous region will have a number of cells. Then the source term in each of those cell will be (Q/total cell volume). But I do not know how you will get this Q value.
Hope this helps
Hiranya
Source Terms in udf vidyaraja Fluent UDF and Scheme Programming 0 April 24, 2009 17:07
UDF: Source terms Novice FLUENT 0 January 13, 2009 04:17
UDF Source terms not producing expected results... Emmanuel Resch FLUENT 0 July 31, 2008 14:55
UDF - source terms Fred FLUENT 2 October 11, 2005 20:53
Convection Terms in UDF Jon Thorpe FLUENT 1 August 14, 2000 09:41
