Home > Forums > FLUENT
Boundary Condition
Old   April 27, 2002, 21:06
Default Boundary Condition
Y.P., Li
Hi, all
I have a question about boundary condition.
I want to perform the simulation of 3-D flow in a square cross-sectional bubble column. The column was initially filled with water. Air was introduced into the system through the small openings at the bottom of the column.
I produced the mesh system using "gambit1.3", but how to set the small openings as inflow boundary instead of the whole bottom of column.
Thanks.
Old   April 29, 2002, 20:45
Default Re: Boundary Condition
Jin-Wook LEE
Set the small opening 'on the whole bottom' and use the Gambit function, 'SPLIT'.
Sincerely, Jinwook
Old   May 7, 2002, 11:02
Y.P., Li
Hi, Lee
May you explain it in detail? How to 'split'? And the key is how to specify this kind of inlet B.C. in fluent?
Thanks.
Thread Tools
Trackbacks are On
Boundary Conditions Thomas P. Abraham Main CFD Forum 19 May 24, 2012 14:57
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 04:23
Domain Imbalance HMR CFX 3 March 6, 2011 20:10
How exactly the "pressure outlet" bdry condition compute properties on the boundary? yating9901 FLUENT 3 June 28, 2010 12:26
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 11:44
