April 27, 2002, 21:06 |
Boundary Condition
Hi, all
I have a question about boundary condition. I want to perform the simulation of 3-D flow in a square cross-sectional bubble column. The column was initially filled with water. Air was introduced into the system through the small openings at the bottom of the column. I produced the mesh system using "gambit1.3", but how to set the small openings as inflow boundary instead of the whole bottom of column. Thanks. |
April 29, 2002, 20:45 |
Re: Boundary Condition
Set the small opening 'on the whole bottom' and use the Gambit function, 'SPLIT'.
Sincerely, Jinwook |
May 7, 2002, 11:02 |
Hi, Lee
May you explain it in detail? How to 'split'? And the key is how to specify this kind of inlet B.C. in fluent? Thanks. |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
Boundary Conditions | Thomas P. Abraham | Main CFD Forum | 20 | July 7, 2013 05:05 |
Setting outlet Pressure boundary condition using CAFFA code | Mukund Pondkule | Main CFD Forum | 0 | March 16, 2011 03:23 |
How exactly the "pressure outlet" bdry condition compute properties on the boundary? | yating9901 | FLUENT | 3 | June 28, 2010 12:26 |
How to set boundary condition in Fluent for the fo | Peiyong | FLUENT | 1 | November 10, 2006 11:44 |
