Home > Forums > FLUENT
solid with temperatur
Old   May 15, 2002, 05:39
Default solid with temperatur
Konstantin Philipp
Hi! Got a problem of cooling a solid body(steel!). I have to define the temperature inside the body (grid: default interior, nearly 1100K), and not only the temperature at the walls aoutside the body. With transient simulation I want to calculate the surface reaction. Gimme a hint, please!
Old   May 15, 2002, 16:19
Default Re: solid with temperatur
JiChun
Your problem is a conjugate heat transfer problem. Your computational domain should include both the solid body(steel) and the fluid doamin. In GAMBIT, define these two different zones as solid and fluid zones respectively. I think your calcuation should also include radiation since the temperature is very high. I don't know what kind of help you want. Your question seems unclear to me.
Old   May 16, 2002, 05:01
Konstantin Philipp
That's cool! The most thing I like on internet is having contact with persons thousands miles away from me! By the way, thank you for your response JiChun! The problem is: how to define uniform temperature (1100K) at the beginning of the simulation inside the body, not only at the surface (wall). The aim is to compute the temperature-distribution inside the solid over time. Maybe this is more information.
Old   May 16, 2002, 07:19
Erwin
Define a small portion of your zone in Gambit as a separate solid zone, call it for example 'core'. Then in Fluent you can set the initial value of core to be at whatever temperature. You can use either the 'initialize' or 'patch' command. Especially patching the zones might be useful for you.
Old   May 16, 2002, 15:29
JiChun
That's too easy, just do as what I said, then in FLUENT select the solid zone and patch a uniform temperature 1100K to this region. That's it.
Old   May 22, 2002, 09:52
Default One more question
David Shkval
Excuse me, here is one more question:
As appear in transient conjugate problems, we shall simulate unsteady history of the heat transfering. Here comes "rigid" problem when time scale in fluid zones compared to that in solid zones. e.g., as limited by the stability of solver in fluid zones, each real time step may uplimited to 10^4, while time step in solid zones can be much more larger than this value.
My problem is: when simulate hypersonic conjugate heat transfer problem, since up-limits of time step in solid&fluid zones are different(maybe 10^4 : 1), which solver shall we use in Fluent?
1. explicit scheme: convergence is difficult and costly. 2. implicit scheme with pre-condictioning method: dunno if it's suitable in hypersonic case.
Old   May 23, 2002, 13:20
Default Re: One more question
Alammar
Your best bet is to use the coupled, implicit solver. Theoretically, it's unconditionally stable; i.e., time step is not a problem. However, you might develop some instabilities due to, for example, high gradients of shocks and reactions; but then you can relax your scheme temporarly with the Courant number. If you use the segregate solver, you're gonna end up under-relaxing your equations big time!
Old   May 24, 2002, 04:46
David Shkval
thank u Alammar, I'll try
Thread Tools
Trackbacks are On
How model radiation of both solid wall and fluid£¿ Harry Qiu FLUENT 2 February 4, 2013 00:04
Solid combustion problem.... godspeedsam FLUENT 2 February 21, 2010 18:46
Defining Solid Zones Not working elmcmaster FLUENT 3 May 22, 2009 07:14
Multiple Solid Domains - Interfaces Scott CFX 8 July 31, 2008 15:20
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
