UDF Hooks
Dear all,
I am using User-Definded Funtion Hooks(UDFH) as my k-e boundary conditions are changing with the inlet velocity condition. I have set "initialization function" as inlet velocity, However the results were same as not using this UDF Hooks. Can anyone tell me what this UDFH actually does? Thanks sam |
Re: UDF Hooks
You don't need to use "initialization function"(DEFINE_ININT) and DEFINE_PROFILE function should be used. This function "DEFINE_INIT" is used when all solutions are initialized(i.e. At an initial iteration ). Keil |
Re: UDF Hooks
Thanks Keil.
I still don't fully understand. Maybe I need to explain my case a bit more. I have 3 inlet condition for a Jet using k-e model. (A) inlet Velocity(e.g changes with time u= u(t)) (B) k (e.g changes with the inlet velocity= const*A^1.5) (C) e (e.g changes with k = const*B^2) after calculating A then B and C. My intention was to update the condition B&C based on condition A as the TIME varies like inlet velocity. Do I still need to use DEFINE_PROFILE? and when the initialization function in GUI, do I need to include DEFINE_INNT in the C code? P.S If it's possible I would like to send you an e-mail with my C code. my e-mail is airsaint@hotmail.com |
Re: UDF Hooks
Yes, it's O.K you can do it.
The combination of DEFINE_PROFILE and DEFINE_INIT is good for your problem. You have to specify the initial value of K and E in DEFINE_INIT function and specify the time-dependent values in DEFINE_PROFILE function |
