UDF Hooks
Old   May 16, 2002, 06:44
Default UDF Hooks
Sam
Dear all,
I am using User-Definded Funtion Hooks(UDFH) as my k-e boundary conditions are changing with the inlet velocity condition.
I have set "initialization function" as inlet velocity, However the results were same as not using this UDF Hooks.
Can anyone tell me what this UDFH actually does?
Thanks
sam
Old   May 17, 2002, 02:59
Default Re: UDF Hooks
Keil
You don't need to use "initialization function"(DEFINE_ININT) and DEFINE_PROFILE function should be used.
This function "DEFINE_INIT" is used when all solutions are initialized(i.e. At an initial iteration ).
Keil
Old   May 17, 2002, 04:11
Sam
Thanks Keil.
I still don't fully understand. Maybe I need to explain my case a bit more. I have 3 inlet condition for a Jet using k-e model. (A) inlet Velocity(e.g changes with time u= u(t))
(B) k (e.g changes with the inlet velocity= const*A^1.5)
(C) e (e.g changes with k = const*B^2)
after calculating A then B and C.
My intention was to update the condition B&C based on condition A as the TIME varies like inlet velocity.
Do I still need to use DEFINE_PROFILE? and when the initialization function in GUI, do I need to include DEFINE_INNT in the C code?
P.S If it's possible I would like to send you an e-mail with my C code. my e-mail is airsaint@hotmail.com
Old   May 17, 2002, 08:11
Keil
Yes, it's O.K you can do it.
The combination of DEFINE_PROFILE and DEFINE_INIT is good for your problem.
You have to specify the initial value of K and E in DEFINE_INIT function and specify the time-dependent values in DEFINE_PROFILE function
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
