May 27, 2002, 09:23 |
Turbulent heat transfer calculation
Hello everybody,
I try to calculate turbulent heat transfer on a turbine vane. I checked out all available models in Fluent (k-e, k-w, ...) with all wall approaches. I have not found any model which gives satisfactory results compared to validated experiments. This means overprediction of the heat transfer on the suction side with 50 to 100 %. I get good agreements between experiments and calculations if I use a simple 2D bounary layer code. So now my questions: 1.) Have other users similar experiences ? 2.) Is there a public source (eg. on the www) with validation examples for calculation of turbulent heat transfer: plane plate, impinging jet, backward facing step, turbine vanes and blades, etc. ? Thank you very much in advance for your comments. Frank |
May 28, 2002, 11:13 |
Re: Turbulent heat transfer calculation
I have gotten very good results for flow in empty pipes and with a swirl (with twisted tapes). The CFD results were within 10 - 15% of the empirical methods. For a good quantitative prediction it is essential that the bounday layers are properly resolved. Pay extra good attention to the y+ values.
May 29, 2002, 14:37 |
hi Erwin can you please give more details about:- 1-what turbulent model did you use? 2-Re=? 3-did you use hexa or tetra? 4-what was your fluid properties? 5-what was your y+?
thanks |
Solver for an incompressible, turbulent flow with heat transfer | tH3f0rC3 | OpenFOAM Running, Solving & CFD | 9 | June 17, 2019 06:12 |
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff | swahono | OpenFOAM Running, Solving & CFD | 10 | October 15, 2018 05:43 |
heat transfer calculation | ynsudo | OpenFOAM Running, Solving & CFD | 0 | September 16, 2010 07:57 |
Turbulent Heat Transfer Transport Equation | Flo.duck | Main CFD Forum | 0 | May 6, 2009 03:37 |
Heat transfer coefficent in turbulent flow | Ola Lindgren | Main CFD Forum | 2 | November 17, 1998 05:49 |
