-   -   Error (ACCESS VIOLATION) with UDF (http://www.cfd-online.com/Forums/fluent/29814-error-access-violation-udf.html)
Ale May 27, 2002 09:21
Hi to all! I wrote a code for interpreted UDF (Fluent5) and I compiled it successfully. I run a simulation and I saved case & data. When I read again case & data I had this error:
Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: ()
Does anybody know which mistake can lead to this error?
Thanks a lot in advance.
chiseung May 27, 2002 23:24
Re: Error (ACCESS VIOLATION) with UDF
Did you remove the "libudf" folder after saving cas & dat files? If so, you have to compile again to read cas & dat file.
Ale May 28, 2002 02:50
Thank you very much for your answer. I'm working with interpreted UDF, so I don't have the "libudf" folder in my working directory.
Anyway, I'm now beginning with compiled UDF, and I think that your advice will be useful.
Thanks again,
Ale
