May 27, 2002, 09:21 |
Error (ACCESS VIOLATION) with UDF
Hi to all! I wrote a code for interpreted UDF (Fluent5) and I compiled it successfully. I run a simulation and I saved case & data. When I read again case & data I had this error:
Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: () Does anybody know which mistake can lead to this error? Thanks a lot in advance. |
May 27, 2002, 23:24 |
Re: Error (ACCESS VIOLATION) with UDF
Did you remove the "libudf" folder after saving cas & dat files? If so, you have to compile again to read cas & dat file.
May 28, 2002, 02:50 |
Thank you very much for your answer. I'm working with interpreted UDF, so I don't have the "libudf" folder in my working directory.
Anyway, I'm now beginning with compiled UDF, and I think that your advice will be useful. Thanks again, Ale |
specified shear at wall - temperature gradient - UDF - access violation error | senD | Fluent UDF and Scheme Programming | 9 | September 18, 2014 07:29 |
udf segmentation violation when hooked | jjchristophe | Fluent UDF and Scheme Programming | 9 | June 25, 2012 05:46 |
udf error : access violation | butterfly007 | Fluent UDF and Scheme Programming | 2 | June 1, 2012 11:01 |
UDF Access violation | therandomestname | FLUENT | 0 | April 15, 2011 17:31 |
UDF problem (ACCESS VIOLATION) | Jorge Poyatos | FLUENT | 5 | March 16, 2009 08:02 |
