May 28, 2002, 14:57 |
multiphase model
I am trying to model recatngular domain. In the upper part : air in the lower part : resin between is a flat free surface
I just want the resin to move at 0.05m/s and see what happens when a solid part is between the two fluids. (normally a bulge ahead of the solid part) I use the multiphase model with volume of fluid. I have a velocity inlet at the left side for the resin, and the rest is walls except the right side which is outflow The resin should roughly stay at the same level (except from the bulge), but when I try, the resin has a very strange shape (it seems that there is less resin than in the beginning), obviously not the one I expect. Do you find any error in my modelling? Please help me! Jeremy |
May 30, 2002, 04:56 |
Re: multiphase model
use unsteady-solver with VOF. Make sure your initial conditions are physical. Use pressure outlet instead of outflow, which probably is more physical. Try the 'body force weighted' scheme in combination with the PISO-scheme for pressure-velocity coupling. Don't forget to turn on gravity. hope this helps, Laika, still orbiting |
Display Modes | |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
Problems bout CFD model of biomass gasification, Downdraft gasifier | wanglong | FLUENT | 2 | November 26, 2009 00:27 |
mass balance problem in multiphase model | mdsanij1 | FLUENT | 0 | July 28, 2009 17:01 |
Multiphase model and species transport | Reginaldo Cotto | FLUENT | 0 | August 29, 2006 21:36 |
multiphase model & separation | naser | FLUENT | 5 | June 9, 2006 07:12 |
