-   -   why I can only use SIMPLE of 1 order? (http://www.cfd-online.com/Forums/fluent/29832-why-i-can-only-use-simple-1-order.html)
quain tchew May 29, 2002 04:28
I'm computing a combustion chamber of an engine which has two subsonic air inlets, a fuel inlet and a nozzle.
I set 1 the air inlets as pressure inlets with totol pressure of about 950000 Pa; 2 the fuel inlet as mass flow inlet with mass flux of 0.09kg/s; 3 the nozzle as pressure outlet with 26000Pa.
I use ideal-gas model, K-E turbulence model with standard wall function. And I used tets mesh, no boundary grid.
Only with SIMPLE method of one order, I got a converged result. But when I switch to two order simple method, it didn't converge.
I don't know why? Any one give some advices?
