Monitor mass flux in multiphase model
Old   May 23, 2002, 09:46
Default Monitor mass flux in multiphase model
Derek Jing
I am modeling gas-particulate phase flow using FLUENT 6 Eulerian model. I hope to monitor the mass flow rate of the solid phase along the exit surface. However, on the panel Solver>Monitors..., when I choose "mass flow rate", there is no place for me to choose the phase that I will monotor. So, in this case, how can I obtain the mas flow rate of one of the phases?
Thank you in advance.
-Derek
Old   May 30, 2002, 15:18
Default Re: Monitor mass flux in multiphase model
fouzi
Hi Derek;
in fluent panel , you use text command :
: report
: mass-flow
: chose your phase
fouzi
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
Selecting the appropriate multiphase model and radiation model panos_metal FLUENT 0 June 18, 2010 07:58
Multiphase model capilor FLUENT 0 June 1, 2010 12:24
air and water vapour mixture - multiphase model Saba FLUENT 0 February 10, 2009 12:05
multiphase mixing Problem with MRF model in MixSim Srinivas FLUENT 0 October 17, 2005 06:35
