root mean square
Old   May 29, 2002, 13:48
Default root mean square
John
Dear ALL
I am currently trying to model water flowing through a pipe in Fluent 5.5. To validate the model I have found a number of published papers on the subject. Many of the papers use a parameter called the 'root mean square velocity'. What does this mean and how can I get it from Fluent?
Thanks in advance, John
Old   May 29, 2002, 17:03
Default Re: root mean square
Steve
Urms is the root mean square of the turbulent fluctuations in the x direction. It can be recovered from the turbulent kinetic energy if the flow is isotropic (i.e. u'=v'=w') using k=1/2(u'^2+v'^2+w'^2). However the flow is unlikely to be isotropic and so if you are using an eddy viscosity model you will need to know the ratio of u':v':w'(which for example is 4:3:2 for equillibrium flat plate flow).
For eddy viscosity models the flow is assumed to be isotropic so it will be difficult. For second-order closures you can recover Urms from the Reynold stresses.
Steve
Old   May 29, 2002, 17:10
Steve
Sorry 4:2:3 not 4:3:2
Old   May 30, 2002, 09:55
John
Hi Steve,
Thank you very much for your response. I am using the k-eps 2 equation model which if I understand correctly assumes the eddy viscosity is the same in all directions. Can I therefore assume that it will be impossible to get the rms of the turbulent fluctuations from Fluent directly (unless I change to the Reynolds stress model) and the only way I can get them indirectly is to know the ratio of u'v'w' for a pipe?
Thanks once again, John
Old   May 30, 2002, 16:14
Steve
Thats correct, however if the data you are comparing to has all three components of the turbulent fluctuations than you could combine them to give k and compare to k from FLUENT.
root mean square velocity Far CFX 12 June 1, 2016 08:58
Fully developed 3d velocity profile: Square inlet! Taru FLUENT 6 September 14, 2015 08:38
OpenFOAM-1.7.0 for CentOS/RHEL/SL 5.x 64bit released linnemann OpenFOAM Installation 66 October 26, 2013 13:04
[OpenFOAM] Installation problem with ParaView 3.8.0 on openSUSE 11.2 aero_ ParaView 14 August 2, 2010 18:13
MPI PROBLEMS gtg627e OpenFOAM Running, Solving & CFD 20 October 5, 2007 04:02
