Home > Forums > FLUENT
Combustion problem, Temp to high.
Old   June 11, 2002, 14:39
Default Combustion problem, Temp to high.
Devin
Hello everyone,
I'm trying to model an HVOF thermal spray process, but I'm having some difficulty. I'm getting temperatures in excess of 4500K when the flame temperature of propylene is approx. 2300K.
The model is using ideal-gas as it is a supersonic flow and the standard k-e model for turbulence. The boundary condition for the fuel inlet is a propylene-oxygen mixture. I suspect this may be my proplem. I've done some other cases involving separate fuel and oxygen supplies with better results.
Any thoughts?
Devin
Old   June 12, 2002, 05:20
Default Re: Combustion problem, Temp to high.
Erwin
Are you using a radiation model to get rid of some energy? That might help.
Old   June 13, 2002, 20:54
Jin-Wook LEE
Flame temperature of propylene 'WITH AIR ' may be approx. 2300K, but flame temperature 'WITH OXYGEN' might be higher than 4500K.
Sincerely, Jinwook
Old   June 14, 2002, 02:29
newbie
What will the flame temperature be for kerosene and how does one go about determining the value? If I am simulating a combustor, how do i know if the flame temperature is too high?
Old   June 16, 2002, 20:37
Jin-Wook LEE
Adiabatic flame temperature of most fuel with 'AIR' as oxidant is about 2000C(~2300K) or higher.
Theoretically, Adiabatic flame temperature of most fuel with OXYGEN as oxidant might be higher than 4000K. But this is only theoretical value. In general they say that, in real experiment, the flame temperature is lower than 4000K because of dissociation.
Calculation of Adiabatic Flame Temperature(AFT) :
Q_in = Integral from T_ref to T_aft dot M Sigma (Cp)_i dot m_i dT
Where,
dot M : total mass flow rate dot m : mass fraction of each species Cp_i : specific heat of each species ...... ......
Sincerely, Jinwook
Old   June 17, 2002, 15:01
Devin
Thanks, everyone, for your input. Greatly appreciated.
Devin
Old   April 26, 2012, 05:46
Mohammed Khan
Mohammed Khan is on a distinguished road
Originally Posted by Devin
;101290
Hello everyone,
Any thoughts?
Devin
Dear Devin,
I am modeling the HVOF process in fluent and I am also getting very high temperature. I hope u got the solution for that. Could u please tell me the solution for getting the temperature around 2500.
Thanks
Mohammed Khan is offline   Reply With Quote
Thread Tools
Trackbacks are On
Problem on EDC model for coal combustion lei FLUENT 4 September 3, 2015 09:39
Problem using EDM for combustion nakul FLUENT 1 August 11, 2011 05:01
High Turbulence Intensity Problem bwg FLUENT 1 January 13, 2010 14:09
Tutorial problem: "rhopSonicFoam - shockTube" with high pressure shangzung OpenFOAM 0 November 1, 2009 14:07
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
