compiler
Old   June 14, 2002, 08:04
Default compiler
stephanie
Hello dear Fluent Users,
I am a new user of Fluent and I would like to compile the following source programm in fluent 6.0.
#include "udf.h"
DEFINE_SOURCE(cell_x_source,cell,thread,dS,eqn) {
float source;
double C,A,dh,S2,S1,SpeedValue,T;
SpeedValue=sqrt(C_U(cell,thread)*C_U(cell,thread)+ C_V(cell,thread)*C_V(cell,thread)+C_W(cell,thread) *C_W(cell,thread));
T = 300.;
C = 1000 ;
A = 0.2;
dh = 0.001;
S2 = pow(C*(C_R(cell,thread)*SpeedValue*dh/C_MU_L(cell,thread)),A);
S1 = T*S2;
source = S1-S2*C_T(cell,thread);
return source;
With cpp I obtain the following error:
cpp -I/usr2/fluent_6012/Fluent.Inc/fluent6.0/src -I/usr2/fluent_6012/Fluent.Inc/fluent6.0/cortex/src -I/usr2/fluent_6012/Fluent.Inc/fluent6.0/client/src -I/usr2/fluent_6012/Fluent.Inc/fluent6.0/multiport/src -I. -DUDFCONFIG_H="<udfconfig.h>" source.csh: cpp: not found
Error: source.c: line 1: Syntax error.
And with cc:
cc -I/usr2/fluent_6012/Fluent.Inc/fluent6.0/src -I/usr2/fluent_6012/Fluent.Inc/fluent6.0/cortex/src -I/usr2/fluent_6012/Fluent.Inc/fluent6.0/client/src -I/usr2/fluent_6012/Fluent.Inc/fluent6.0/multiport/src -I. -DUDFCONFIG_H="<udfconfig.h>" source.cNo such feature exists (-5,116:2) No such file or directory
The MIPSpro C Compiler (license FEATURE string = cc) requires a license password.
For license installation and trouble shooting information visit the web page:
http://www.sgi.com/Support/Licensing/install_docs.html
To obtain a Permanent license (proof of purchase required) or an Evaluation license please visit our license request web page:
http://www.sgi.com/Products/license.html
or send a blank email message to:
license@sgi.com
In North America, Silicon Graphics' customers may request Permanent licenses by sending a facsimile to:
(650) 932-0537
or by calling our technical support hotline
1-800-800-4SGI
If you are Outside of North America or you are not a Silicon Graphics support customer then contact your local support provider.
ld32: ERROR 33 : Unresolved text symbol "main" -- 1st referenced by /usr/lib32/mips4/crt1.o.
Use linker option -v to see when and which objects, archives and dsos are loaded. ld32: ERROR 33 : Unresolved text symbol "sqrt" -- 1st referenced by source.o.
Use linker option -v to see when and which objects, archives and dsos are loaded. ld32: ERROR 33 : Unresolved text symbol "pow" -- 1st referenced by source.o.
Use linker option -v to see when and which objects, archives and dsos are loaded. ld32: INFO 152: Output file removed because of error. Error: source.c: line 1: Syntax error.
Has somebody an idea what the problem could be?
Old   June 14, 2002, 10:23
Default Re: compiler
Damien
Voilą ! ----------------- #include "udf.h"
real source;
real C,A,dh,S2,S1,SpeedValue,T;
T = 300.; C = 1000. ; A = 0.2; dh = 0.001; S2 = pow(C*(C_R(cell,thread)*SpeedValue*dh/C_MU_L(cell,thread)),A); S1 = T*S2; source = S1-S2*C_T(cell,thread); dS[eqn]=-S2; return source;
} ------------------- It works for me, and you? I used it as a compiled UDF, I'm not sure if you are trying to use Interpreted UDF. I prefer to avoid it, especially if its to use it every iteration. I just changed float and double by real. and added the dS[eqn] sequence
I hope it helps
Kind Regards
Damien
Old   June 19, 2002, 07:49
stephanie
Salut Damien,
I could compile the programm. Thank you for your help.
Salutations,
Stephanie
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Fortran compiler Erik Siemens 2 November 28, 2008 20:05
Intel compiler for linux x86 marcus Siemens 1 November 9, 2006 16:43
Fluent 6.2 and gcc compiler in Sun Blade 2500 Nitu Gupta FLUENT 8 April 29, 2005 13:58
Fortran compiler Arnab Siemens 5 September 14, 2004 03:59
