Sliding Mesh Bound Node Loop
Old   June 18, 2002, 15:50
Default Sliding Mesh Bound Node Loop
Rupp Carriveau
My configuration is very simple. I am trying to spin a "hockey puck - like" disk near the water's surface in a funnel which has a steady state flow through it. I have no problem establishing the grid interface at the puck top and at the puck bottom. However, as soon as I try and create the interface for the vertical, circular puck wall in Fluent 6.0.12 for Windows NT, I get the notorious "Bound Node Loop" error. I have attempted some the fixes proposed by Mr. Larsson, but so far have been unsuccessful in resolving what I thought would be a simple fix.
Can anyone offer any suggestions?
Many Thanks!
Old   June 19, 2002, 04:21
Default Re: Sliding Mesh Bound Node Loop
Laika
Your sliding mesh-boundary = the puck's wall?
If so, make the sliding boundary a bit further from the puck as such that there is air on both sides of the sliding interface (non-conformal mesh with fluid on both sides is difficult enough)
hope this helps,
Laika, still orbiting
Old   June 19, 2002, 10:57
Rupp Carriveau
Laika,
Thank you for the advice. Unfortunately, this is exactly how I have the mesh set up. The puck is a solid, and I have a larger "puck of water" enveloping it (which rotates with the solid puck). I have made the interface of this larger "water puck" with the water in the funnel the region for the sliding mesh interface. It really seems straight forward. It is so frustrating to be that close and it still won't let me do it.
If you, or anyone else has something, please let me know. I am nearing wit's end.
Thanks Again!
sliding mesh, confused me, help! help! weiyang1980 FLUENT 2 September 30, 2009 21:45
dynamic mesh and sliding mesh nasser FLUENT 0 November 1, 2005 02:37
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
Bound node loop. Jack Keays FLUENT 5 July 9, 2000 13:57
