-   -   XY plots in Tecplot (http://www.cfd-online.com/Forums/fluent/29932-xy-plots-tecplot.html)
Svend Tollak Munkejord June 21, 2002 04:11
XY plots in Tecplot
Dear all,
I am trying to make XY plots in Tecplot (v. 9) with Fluent (v. 6) data. I am completely new to Fluent, but have used Tecplot before.
I imported the Fluent data (from a regular 2D grid) using the Fluent data loader in Tecplot. The contour plots are OK, but I can't make sensible XY-plots. When I try to plot, say, X velocity as a function of Y, I get many curves on top of each other, and Tecplot says that the maximum "J index" is 1, while I guess it should have been the number of nodes in the Y-direction.
Is this a known problem, and if so, what can be done about it?
Thanks in advance.
Regards, Svend Tollak Munkejord
Ajay S. Parihar June 21, 2002 06:29
Re: XY plots in Tecplot
try to store data in following format and then plot it open(1,file='data') do j=1,Jmax do i=1,imax
write(1,*)u(i,j),y(i,j)
enddo write(1,*) enddo close(1)
You will get correct plot.
Svend Tollak Munkejord June 21, 2002 07:26
How do I apply this to the Fluent data? I do not have the Fluent source code.
-- Svend Tollak Munkejord
