Modelling a Simple Draining Funnel
Old   July 3, 2002, 15:15
Default Modelling a Simple Draining Funnel
Rupp Carriveau
I wondered if anyone new a "simple" procedure for modeling water draining through a funnel. I would like it to be an unsteady problem where the water surface moves as it would under gravity (draining without replenishment). I am unsure if I have to specify all the boundaries as moving, and if I do, am I responsible for dictating the rate?
Thanks,
Rupp.
Old   July 3, 2002, 23:57
Default Re: Modelling a Simple Draining Funnel
Lanre
For simple: check Bird, Stewart and Lightfoot, "Transport Phenomena", and Munson et al, "Fluid Mechanics"
For complex: use a free-surface model like the VOF model in FLUENT. You'll have two phases: gas and liquid (water). Since the gas will be entering from the top of the funnel as the liquid level recedes, you need to specify the pressure at the boundary = Patm. This method will be able to predict (through the correct inputs) vortex formation in the liquid surface.
For more complex: use a moving mesh model. Here you prescribe the motion of the liquid surface through a complex user-defined function on the basis on the analytical solutions provided in the simple approach above
Old   July 4, 2002, 09:00
Rupp Carriveau
Thanks for the great tips! I am anxious to give them a go!
Rupp.
SIMPLE algorithm in 3D cylindrical coordinates zouchu Main CFD Forum 1 January 20, 2014 17:02
Help with Modelling Incompressible Air flow through a verticle funnel Global_pupil Main CFD Forum 0 February 11, 2010 20:18
Advice on multi-phase flow modelling Martin Main CFD Forum 3 October 14, 2008 05:16
Unsteady modelling technique? Carlos FLUENT 0 September 26, 2008 11:37
PISO vs. SIMPLE benedikt flurl Main CFD Forum 2 April 14, 2005 06:54
