Home > Forums > FLUENT
deforming mesh
Old   July 6, 2002, 15:18
Default deforming mesh
Torn
How to set any conditions for deforming mesh in fluent6. Have any one have moving and deforming mesh tutorial?
Regard.
Torn
Old   July 7, 2002, 05:28
Default Re: deforming mesh
bonny
hi,Torn What problem are you doing ? I need these tutorials too. But I did not find any.
Regards bonny
Old   July 7, 2002, 07:52
torn
My problem is about flow in moving cylinder. I known fluent 4 with structure mesh can be work but I want use fluent 6.
regards
Old   July 8, 2002, 01:19
anindya
The Fluent 6.0 tutorials can be found at this website. (http://sp81.msi.umn.edu:999/fluent/f...help/index.htm) There are a couple of moving grid tutorials. See chapter 10 (Using Sliding Meshes) on sliding grids and also chapters 7 and 8 of the Tutorial Guide. Also look at chapter 9 of User Guide(Modeling Flows in Moving Zones). Hope it helps.
Old   July 8, 2002, 06:26
torn
thank you aninda. These tutorial files are moving grid tutorials but there are not deforming mesh guide.
regards.
Old   July 8, 2002, 09:58
pp
You have this tutorials on
http://www.fluentusers.com
Regards, Pero
Old   July 9, 2002, 03:59
bonny
hi,torn do you have fluent4.5 ? the model of moving and deforming mesh is a separate model, if you buy this model ,you can get these tutorials . but I have nothing.
I want to simulate the fuild flow in scroll compressor chamber ,it is similar to your problem, how about you ?
any advice is appreciated. bonny
Old   July 10, 2002, 03:27
Torn
Hi Bonny, I think your research is so difficult. your mesh are moving and deforming. I don't know how to model geometry when the roter contact the stator. and I think both fluent 4(structured) and fluent 6 (unstructured) can not apply to this application but star-cd may be.
what is version of fluent that you used?
my advice may be incorrect, don't worry.
torn
Old   July 12, 2002, 03:19
Chetan Kadakia
Could you explain why your mesh needs to deform?
Old   July 12, 2002, 18:37
Duc
Thorn,
I just started using Fluent last month, I will also be looking at dynamic meshing soon.
You can find deforming mesh tutorial guide in
http://www.fluentusers.com/fluent6/d...h/main_pre.htm
If you don't have password, you'll need to email a request.
Regards,
Duc
Thread Tools
Trackbacks are On
Problem with deforming mesh Roland R CFX 2 February 28, 2011 15:29
deforming mesh issue : I don't get how stiffness works bennn CFX 9 October 12, 2010 15:09
SnappyHexMesh for internal Flow vishwa OpenFOAM 21 February 27, 2010 03:47
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
