July 6, 2002, 15:18 |
deforming mesh
How to set any conditions for deforming mesh in fluent6. Have any one have moving and deforming mesh tutorial?
Regard. Torn |
July 7, 2002, 05:28 |
Re: deforming mesh
hi,Torn What problem are you doing ? I need these tutorials too. But I did not find any.
Regards bonny |
July 7, 2002, 07:52 |
Re: deforming mesh
My problem is about flow in moving cylinder. I known fluent 4 with structure mesh can be work but I want use fluent 6.
regards |
July 8, 2002, 01:19 |
Re: deforming mesh
The Fluent 6.0 tutorials can be found at this website. (http://sp81.msi.umn.edu:999/fluent/f...help/index.htm) There are a couple of moving grid tutorials. See chapter 10 (Using Sliding Meshes) on sliding grids and also chapters 7 and 8 of the Tutorial Guide. Also look at chapter 9 of User Guide(Modeling Flows in Moving Zones). Hope it helps.
July 8, 2002, 06:26 |
Re: deforming mesh
thank you aninda. These tutorial files are moving grid tutorials but there are not deforming mesh guide.
regards. |
July 8, 2002, 09:58 |
Re: deforming mesh
July 9, 2002, 03:59 |
Re: deforming mesh
hi,torn do you have fluent4.5 ? the model of moving and deforming mesh is a separate model, if you buy this model ,you can get these tutorials . but I have nothing.
I want to simulate the fuild flow in scroll compressor chamber ,it is similar to your problem, how about you ? any advice is appreciated. bonny |
July 10, 2002, 03:27 |
Re: deforming mesh
Hi Bonny, I think your research is so difficult. your mesh are moving and deforming. I don't know how to model geometry when the roter contact the stator. and I think both fluent 4(structured) and fluent 6 (unstructured) can not apply to this application but star-cd may be.
what is version of fluent that you used? my advice may be incorrect, don't worry. torn |
July 12, 2002, 03:19 |
Re: deforming mesh
Could you explain why your mesh needs to deform?
July 12, 2002, 18:37 |
Re: deforming mesh
Thorn,
I just started using Fluent last month, I will also be looking at dynamic meshing soon. You can find deforming mesh tutorial guide in http://www.fluentusers.com/fluent6/d...h/main_pre.htm If you don't have password, you'll need to email a request. Regards, Duc |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
Problem with deforming mesh | Roland R | CFX | 2 | February 28, 2011 15:29 |
deforming mesh issue : I don't get how stiffness works | bennn | CFX | 9 | October 12, 2010 15:09 |
basic of mesh refinement | arya | CFX | 4 | June 19, 2007 12:21 |
