-   -   Temperature at grid points.. (http://www.cfd-online.com/Forums/fluent/30050-temperature-grid-points.html)
Elana July 18, 2002 22:39
DEar All,
Im trying to input volumetric heat generation inside an the annulus of a small duct. After iteration i realise that there arent any temprature distribution inside the annulus..jus shows an even red coloured region of maximum temperature. Is there a way to check the temperature at everygrid point in the inside of the annulus?..I have to locate the point where the maximum temeprature occurs.. Plz help Thnk u
Elana
Karunakar July 21, 2002 16:53
Re: Temperature at grid points..
Change auto scale to set range and change the magnitude according to the know temp., range. Play with set range till you see the desired contour.
