July 18, 2002, 22:39 |
Temperature at grid points..
DEar All,
Im trying to input volumetric heat generation inside an the annulus of a small duct. After iteration i realise that there arent any temprature distribution inside the annulus..jus shows an even red coloured region of maximum temperature. Is there a way to check the temperature at everygrid point in the inside of the annulus?..I have to locate the point where the maximum temeprature occurs.. Plz help Thnk u Elana |
July 21, 2002, 16:53 |
Re: Temperature at grid points..
Change auto scale to set range and change the magnitude according to the know temp., range. Play with set range till you see the desired contour.
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
[swak4Foam] adjust inlet temperature depending on values of monitor points (groovyBC) | braennstroem | OpenFOAM Community Contributions | 2 | May 31, 2011 13:45 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
Temperature went outside of its upper limit | Atit Koonsrisuk | CFX | 0 | January 8, 2004 11:43 |
Temperature in vessel during throttling process | Astrid | Main CFD Forum | 2 | January 31, 2001 02:34 |
