Surafce reaction on turbulent gas flow
Old   July 22, 2002, 17:31
Default Surafce reaction on turbulent gas flow
Soma
Hi everyone
I am new user of fluent, and I just started using fluent 5.5. My problem is on modeling the combustion process (btn methane and air) in cylindrical reaction vessel. The process is designed to be premixed combustion process, supported by catalyst in order to lower the combustion ignition temp. and NOx formation.
But after reading the fluent's manual I realised that surface reaction is only suported for laminar flow in the fluent. So Please any one already encounted the same problem as I do?? and how you go about it??
I am thinking of introducing UDF for surface reaction in order to use with the turbulence code, is it possible to do so?? any one tried it before..??
I will appreciate if I get any responce which will enlight and easy my problem.
Thank you in adavance
Soma
Particle deposition on circular cylinder in turbulent flow Julian K. CFX 1 October 3, 2011 17:51
Turbulent compressible and subsonic gas flow Rasmus Gjesing (Gjesing) OpenFOAM Running, Solving & CFD 42 May 30, 2005 13:38
Reynolds and Turbulent Flow Frederic Dubinski Main CFD Forum 2 October 20, 2004 13:57
ideal gas law in turbulent flow Achim Siemens 0 March 26, 2003 14:38
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
