Graphics Error...Help needed!
I installed Fluent on a new computer and when i start Fluent, read a mesh file and want to diplay e.g. the grid, the window which opens is completely white and it reads the following message in the Fluent window: Error: Fluent received a fatal signal (ILLEGAL INSTRUCTION) Error Object: () does anyone know what to do? Thank you very much in advance! Stefan
Re: Graphics Error...Help needed!
Stefan, You may have some OpenGL problems. I know I have that same problem when working with our UNIX emulators. If you are using a unix box, you might want to export the graphics as x-windows. Use this command in your command line
%fluent -driver X11 Matt |
Thank you Matt for your reply, i finally made it with the command: Fluent -driver msw i also contacted the company (Matrox) if they can give me further help. Stefan
