Boundary flow
Old   July 24, 2002, 10:42
Default Boundary flow
Glenn
Is it possible to have flow going in followed by flow going out across the same boundary?? Im using Gambit 2.0 and Fluent 5.5 Thanks
Old   July 25, 2002, 03:38
Default Re: Boundary flow
Laika
Yes, just use a pressure inlet and a pressure outlet. Thes can handle negative velocities that make an inlet be an outlet and vice versa.
I suppose you have a transient simulation.
Make sure these boundary conditions match the physics of your fow. If you're not sure, take in your simulation domain a region around the inlet and outlet as well.
good luck,
Laika, still orbiting
Boundary condition problem for open channel flow Andy CFX 9 June 11, 2016 07:20
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
